Nvidia drivers.
gleneagles
Aspiring Legend
Fixes: 17
Nvidia drivers.
Installed Nvidia driver on windows 7 and everything works ok but Mint 15 does not seem to happy with it, runs but message appears about high level of cpu use due to driver problem.
Is it a simple matter of going to the Nvidia site and downloading the Linux driver or will that mess up the driver for windows ?
We are born into history and history is born into us.
7 REPLIES 7
HairyMcbiker
All Star
Fixes: 21
Re: Nvidia drivers.
Did you run the new driver selector?
Can't remember its name just now and using M14 here. But the new selector tool will download and install the latest driver for you, saves having to faff about removing the other drivers.
Also which NV card it it?
Oldjim
Fixes: 63
Re: Nvidia drivers.
Really silly question - you did install the correct driver under Mint didn't you  Embarrassed
and you might like to check here http://forums.thinkbroadband.com/windows/f/4241379-latest-nvidia-drivers.html
HairyMcbiker
All Star
Fixes: 21
Re: Nvidia drivers.
Silly me it is called MintDrivers!
gleneagles
Aspiring Legend
Fixes: 17
Re: Nvidia drivers.
NVIDIA Geforce GT 620
downloaded the following file from the Nvidia site  NVIDIA-linux-x86-64-319.23.run
HairyMcbiker
All Star
Fixes: 21
Re: Nvidia drivers.
Did you try MintDrivers?
gleneagles
Aspiring Legend
Fixes: 17
Re: Nvidia drivers.
yes but I made a bodge of it and had to reinstall everything.
gleneagles
Aspiring Legend
Fixes: 17
Re: Nvidia drivers.
Got it right at last.........Driver manager is the way to go.
