Now An Ubuntu User!!
- Re: Now An Ubuntu User!!
22-09-2009 2:52 PM
well to the regulars here you may of known i was trying out mint,But i decided to give ubuntu 9.04 a try to see if i liked that better as ive heard great things about this also.
I like ubuntu better than mint,infact so much that windows is gone completetly MMWWAA HAHAHAHA!!
Just a few security queries,ive not bothered with a firewall and i know i dont need antivirus but should i be protected against key loggers or spyware? i do my banking online and few other transactions and just wouldnt like it falling in the wrong hands? Thanks very much for your help in advance
22-09-2009 4:21 PM
Provided that you are using a proper ADSL router, with NAT turned on and wireless turned off you are pretty safe.
Don't let your browser store passwords etc which you use for banks etc.
It's always worked for me.
Obviously, don't click on links in emails supposedly from your bank - obvious, but not to non-technical types!
[edit] Don't sign-on as root.
22-09-2009 6:09 PM
22-09-2009 6:25 PM
With regards to Ubuntu security I use the firewall but not antivirus. I also store passwords but obviously not banking ones. I've also recently gone back to NoScript which I have used on and off in Windows for a while. I find it a bit of a pain but persevering because it is supposed to be good.
BTW why did you switch to Ubuntu?
22-09-2009 6:42 PM
I am using no script and its a pain to begin with till it knows what you dont want blocked,also running ad block and better privacy 1.29.Yeah ditching windows was the decision i made a while back,i dont need a high spec pc with the latest windows that costs an arm and a leg not to mention all the security software you need in windows,because all i really use my pc for is online banking,checking emails,visiting a few forums and basically just surfing the net,I feel i can do all this with a linux op and doesnt cost me the arm and a leg plus ill be geting free updates for life,now who can refuse that lol,also i believed ubuntu to be the most popular so thats why ive chosen ubuntu although under the skin its really pretty much like mint,but now its installed and windows is gone i will be sticking with this op for sometime,unless i wana try out another linux to play with
22-09-2009 6:48 PM
Ubuntu/Linux is therefore spot on.
Only thing I need Windows for is my crafting CD's and also like to use Publisher.
22-09-2009 7:45 PM
Quote from: steve74 Yeah ive never allowed any web browser to store my passwords as i just dont feel comfy with that idea,im using a router supplied by plusnet and i do have wireless on as my xbox 360 connects too it,but i dont have my name broadcast so i dont think my router would be easily found....
When your xbox looks for your router it easily finds it - non-broadcasting your SSID is no security.
Make sure you are using encryption - preferably WPA, although WEP will protect you against non-aggressive action.
Ensure that you change your router configured password that you use to access your router for administration purposes (this is not your PlusNet password).
22-09-2009 8:08 PM
23-09-2009 11:40 AM
Bit of a pain!
23-09-2009 1:17 PM
Ubuntu/Mint doesn't really need a firewall as all ports are closed by default, so nobody can get in. Keyloggers and spyware are not an issue because they are written as Windows applications, and they simply won't work on Linux. As a normal user on Linux you can't install software anyway, so even if there were any Linux malware apps they would not be able to install themselves. Installing software always needs a root password.
@poppy, if you mean burning CDs then the apps built in to Linux are perfectly good. For desktop publishing check out Scribus for Linux. Not quite as easy to use as InDesign etc (I'm not familiar with Publisher), but fine once you get used to where everything is. Scribus's colour management and PDF export is excellent.
23-09-2009 1:29 PM
Quote from: Denzil Ubuntu/Mint doesn't really need a firewall as all ports are closed by default, so nobody can get in. Keyloggers and spyware are not an issue because they are written as Windows applications, and they simply won't work on Linux.
But isn't there a danger that people will start writing viruses and spyware to target Linux?
Quote from: Denzil As a normal user on Linux you can't install software anyway, so even if there were any Linux malware apps they would not be able to install themselves. Installing software always needs a root password.
I don't understand this. I've built a MINT laptop that only has one account. When I log-in I can install things from the Package Manager so does that mean that I'm effectivly logged in as root?
Bob
23-09-2009 1:37 PM
Provided it asks for a password, and that you do this only when you expect it, you are safe.
[Passwords are stored as a one-way encrypted form - it can test if a trial password is correct, but you can't generate a password from the stored encrypted version]
23-09-2009 2:07 PM
Quote don't understand this. I've built a MINT laptop that only has one account. When I log-in I can install things from the Package Manager so does that mean that I'm effectivly logged in as root?
As Jeremy says, dont know about Mint but thats not how Ubuntu works. Even when you have only one account ( which has administrator/root privileges ) it doesnt automatically log you in with those privileges, unlike Windows!. When you try and do something that requires privilege ( like sudo or installing packages ) it will ask you for the password at the time.
23-09-2009 2:35 PM
Press CTRL-C to terminate.
It will show your top running processes; you should see a lot of root processes, but also the user name you use to login.
If you don't see your user name...
23-09-2009 2:46 PM
Bob
