Not Receiving Emails at Additional Address
- Re: Not Receiving Emails at Additional Address
01-06-2009 2:01 PM
Yours,
Stuart Hall
01-06-2009 2:05 PM
If you setup an additional mailbox, you will need to use a different logic.
So - My account username is "bailey" and I set up an additional mailbox called "james".
My login for that mailbox would then be "bailey+james" and using the password I chose for the mailbox.
Apologies is this is something you knew already!
01-06-2009 3:05 PM
Yours,
Stuart
01-06-2009 3:14 PM
If it's a sepatrate mailbox you'll need to add a new account to OE but the user name becomes username+mailboxname (including the +) where the username is YOUR plusnet username. The password will be whatever you set up when creating the mailbox.
If you set up an alias then mail should be delivered into your mailbox.
01-06-2009 5:40 PM
I am keen to persever with accessing the mailbox as it stands because I don't want to lose all the emails that I know have been sent to it. Can you give me some more advice as to what to do now, please?
Yours,
Stuart
01-06-2009 5:54 PM
https://webmail.plus.net/src/login.php
Login to webmail is username+wifesname with the password you set up for the account or your normal Plusnet password if you didn't set up a separate one
01-06-2009 6:03 PM
I've done as you suggest, and the missing emails are there, thank you. Is it now possible to fix OE for me, please?
Yours,
Stuart
01-06-2009 6:05 PM
Have a look here. It probably doesn't say much more than I've already said.
Best bet is to check and see what you called the mailbox in your settings here. (Member Centre>Email Settings>Manage My Mail if the link fails).
The mailbox username is the bit before the @ in the line marked "mailbox" in the "type" column. (The first mailbox in the list is the default one i.e. yours. This is normally followed by the "postmaster" alias and then by the next mailbox.)
If you logged into webmail OK then it's the same username that you need to put into OE.
Paul
01-06-2009 6:16 PM
01-06-2009 7:08 PM
01-06-2009 7:15 PM
01-06-2009 9:24 PM
01-06-2009 10:39 PM
Works for me any way
01-06-2009 11:00 PM
Quote Manage multiple e-mail and newsgroup accounts
If you have several e-mail or newsgroup accounts, you can work with all of them within one window. You can also create multiple users, or identities, for the same computer. Each identity has unique e-mail folders and an individual Address Book. Multiple identities make it easy for you to keep work e-mail separate from personal e-mail, and also to keep individual users' e-mail separated.
02-06-2009 7:30 AM
Using File>Switch Identities will allow you to move between identities and keep separate inboxes for each identity.
