Noscript
gleneagles
Aspiring Legend
Fixes: 17
Noscript
Is there any point or advantage in having no script installed on a Linux system, ok I know it's actually installed on firefox rather than the OS but is it necessary if using Linux ?
We are born into history and history is born into us.
3 REPLIES 3
HairyMcbiker
All Star
Fixes: 21
Re: Noscript
Don't use it myself, what does it do?
CX
Re: Noscript
If you're concerned enough to use NoScript, then yes, you would need it in Firefox irrespective of OS.
Personally, although I used to use it, too many sites make use of JavaScript these days to effectively use whitelisting (in terms of frustration factor), and as for managing activation of plugins (Flash, Silverlight etc), the browser itself now has good enough controls. I was using it mainly for stopping annoyances, rather than security concerns.
avatastic
Re: Noscript
I'm happy with Adblock Plus and the MVPS hosts file served, which I've got plugged in to my DNS server so the entire LAN gets the benefit.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
