Non Installable Zip Client?
- Re: Non Installable Zip Client?
20-02-2008 2:23 PM
Does anyone know of a zip client that doesn't need to be installed? So that it could either be run from or copied from a USB stick to the target PC without installing first?
2 REPLIES 2
20-02-2008 2:34 PM
Not sure if this is what you're after, but you can get 7zip portable which will run from USB or a folder on the PC... would that do? It can handle zip and rar files too.
Hope that helps,
Hope that helps,
20-02-2008 2:50 PM
Peace be with you orbrey...
Sounds Perfect!
Cheers.
Sounds Perfect!
Cheers.
