Nokia N95 unlock code (security not PIN)
onlyme
Just bought one of these on eBay. When switched on the phone asks for the Lock Code and the previous owner cannot remember it. The phone will not go beyond the Lock Code screen.  I know the default is 12345, but this does not work and I have also tried the "Call, *, 3" method without success.  Do any of you clever guys out there know how to reset or bypass the code?.  Cry
11 REPLIES 11
Njal
Re: Nokia N95 unlock code (security not PIN)
Try:
FORMATTING CODES
*#7370# .......... Format phone...[Hard-Reset]
*#7780# .......... Factory Reset
http://www.nokiausers.net/forum/general-95/10798-help-me-reset-nokia-nokia-n95-locking-code.html
Edit: Sorry looks as though both of those ask for the security code.
Regards
Neil
Njal
According to
http://thinkabdul.com/2007/05/05/tip-soft-and-hard-resetformat-codes-for-nokia-n95/
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3″ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Seems to work on some phones but not others.
According to
http://www.imserba.com/forum/showthread.php?t=110528
Nemesis Service Suite from
http://www.b-phreaks.co.uk/index.php?main_page=page_2&zenid=87c15838cdb7fa92d26f0cdf14167dc0
will read the code from the phone.
Regards,
Neil
onlyme
@njal,  Thanks but I have tried all that. Tried Nemesis but it will only read codes from phones which are accessable, i.e. they must turn on past the lock code.  Formatting codes like *#7370# only work in the same way.  My problem is that I can't get past the opening screen "Enter Lock Code".
Njal
Nokia service centre then?
Regards,
Neil
scootie
get them to do a refund on this item as if they did not state in the description that it was locked and they didn't know the lock code then you have a full right to get a refund.
nice phone tho i was after one a while ago so that i could run spotify on it
onlyme
@njal.  Nokia Service Centre charge about £30 to reflash.  Will cost me £20 for fuel to get there !!!
@asbo dog.  Yeah, right, I am in conversation with the seller for refund. I might have one for you shortly.
                        Regards, Dave.
Fixes: 585
If you wanted to send it to a Nokia Service Centre I can recommend these people http://www.nokiarepairs.net/
I sent my N95 for a screen replacment a while ago and it was back within 48 hours, although I did use Royal Mail Special Delivery rather than the Freepost ( probably wise given the value of an N95!! ).
Strat
Fixes: 565
http://www.nokiarepairs.net/allfaqs.asp?cate=17
wacky17
I would do what Asbo Dog said 'get a refund' but apart from that cant you flash it yourself as you can do it with sony ericsson phones.
onlyme
Guess what? The seller just gave me the code, funny how he found it when I asked for refund.
Nokia reflashing software is not available on the web, I've looked everywhere, I can't find any. Software updates are available free from Nokia site.
Replacing the LCD on N95's is dead easy, just put one on this phone.  £5.33 on eBay, T5 screwdriver, 4 screws to remove, less than10 minutes.
I'll check it out now, fit new housing and resell for about £80.  Want it 'asbo dog' ?  Oh; and reset the code to 12345.
Thanks everyone. Smiley
Strat
Fixes: 565
Well done...good result Smiley
