No wireless on new Thomson?
- No wireless on new Thomson?
08-08-2009 10:29 AM
Could do with a little help guys. I am ok with computers wireless etc. but I have just set my dad up a couple of days ago on Plusnet broadband for the first time. He has been sent the wireless 4 port Thomson router. Finally we got it going, but there is no wireless signal. The light isn't on and I don't detect it. there is a little push button switch on he front, but that doesn't seem to work. Does it come set to 'off' by default? I looked at the menu, but for some reason on my dads monitor, running at 1024 x 768 the router config screen is tiny, miniscule in fact! I can't read anything! are there some settings to activate. The set up leaflet implies it is already running and ready to log into?
2 REPLIES 2
Re: No wireless on new Thomson?
08-08-2009 11:55 AM
Have you tried pushing the button for about 5 to 10 seconds - ?
It may not mention it here, but this
http://www.plus.net/support/broadband/hardware/t585v7new.shtml
Try Ctrl + on your browser - this should enlarge the image
goto
http://192.168.1.254/cgi/b/_wli_/cfg/?be=0&l0=3&l1=1&name=WLAN:
and you should see if the inteface is enabled or not together with the netwrok name (SSID )
and the encryption:
WPA-PSK Encryption Key:
make sure that is on:
goto
and the encryption:
10-08-2009 9:38 AM
I set up a Thomson router supplied by Plusnet last Friday. The wireless was already running and ready to log into.
