No usage stats since Option changed
Gel
Seasoned Pro
Fixes: 12
Is there an issue on Usage Stats; my package changed 10th, and no stats available  today?? Cry
So that doesn't seem to have fixed, unless there's time lag.
I was paying £14.99 a month on previous 2gb package, which I thought was Opt 1.
Fixes: 82
Re: No usage stats since Option changed
I'm not aware of any service-wide issues. I've refreshed your account to see if that makes any difference (you might receive some account change emails but you can ignore these). Bump this thread tomorrow afternoon if there's still been no change.
Fixes: 162
You'll need to change your login details to move off RIN for usage stats to appear on the package you're now on. In your modem/router change the login name to username@plusdsl.net and that should start collecting data.
 Chris Parr
 Plusnet Staff
Gel
Seasoned Pro
Fixes: 12
Fixes: 162
I bet you were on PAYG when it worked? That's the only product that RIN was designed to show usage on.
 Chris Parr
 Plusnet Staff
Gel
Seasoned Pro
Fixes: 12
Fixes: 162
Odd, doesn't show that from here  Shocked From what I can see you were on PAYG from April 06 until the 10th Jan 2009.
 Chris Parr
 Plusnet Staff
Gel
Seasoned Pro
Fixes: 12
James
Hi Gel,
I'm able to see usage stats on your account.  Are you still unable to do so?
Gel
Seasoned Pro
Fixes: 12
