No internet
FIXED- Subscribe to RSS Feed
- No internet
15-10-2017 9:31 AM
I have just replaced my ageing Netgear router with a TP-Link AC1200. The automatic setup went without a hitch except it reports "No Internet", advising me to check the connection in Windows settings/Network and Connections, which only confirms there is no internet connection with a message to turn on the connection.
Great, except there is no obvious way to do this. The Troubleshooting option simply confirms there is a DNS error, but not how to fix it. Any suggestions will be gratefully accepted.
I expect like most of my pleas for help here there is a ridiculously simple answer...
Win 10 with the latest updates.
I am of course using the reconnected Netgear for this.
Fixed! Go to the fix.
15-10-2017 12:08 PM
It sounds like you are using a cable router, you do not mention having to put a username or password into it. Does it work if you plug the TP Link internet connection into a LAN port of the Netgear?
Re: No internet
15-10-2017 1:31 PM
Bleep!, bleep!, bleep!...
A lesson in how to make very very basic mistakes:
Always read the box before purchase.
Thank you Mustrum.
