No internet access on XP computer- HELP - Fixed but I don't know why
- Re: No internet access on XP computer- HELP
08-12-2015 3:21 PM
It accesses the network and sees the other computer on it
ipconfig /all doesn't show up any problem
Putting in the IP address doesn't work either
08-12-2015 3:29 PM
08-12-2015 3:37 PM
08-12-2015 3:43 PM
https://technet.microsoft.com/en-gb/library/bb490921.aspx
08-12-2015 3:49 PM
does this help
C:\*****>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x20002 ...00 0f ea 37 1a aa ...... NVIDIA nForce Networking Controller - Packet
Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.103 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.1.0 255.255.255.0 192.168.1.103 192.168.1.103 20
192.168.1.103 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.1.255 255.255.255.255 192.168.1.103 192.168.1.103 20
224.0.0.0 240.0.0.0 192.168.1.103 192.168.1.103 20
255.255.255.255 255.255.255.255 192.168.1.103 192.168.1.103 1
Default Gateway: 192.168.1.254
08-12-2015 3:50 PM
Turned out to be internet explorer - version 6 (default) only uses 64bit encryption - so when trying to visit google (which defaults to https / SSL) IE couldn't handle the encryption / decrupt it and thus claimed it couldn't connect.
Upgraded IE (or installed a mozilla browser) and bingo... internet worked. I only noticed as my partners laptop IE worked but my other machines (inc virtuals) didn't... and hers was version 7 of IE. When I looked at the about tab I noticed the installed encryption was 128 or 256 bits (can't remember which now).
Not sure if that helps as you've not mentioned the browser but if by any chance it is IE 6, ditch it as it can't handle modern SSL.
08-12-2015 3:57 PM
08-12-2015 4:11 PM
Device manager shows no problems
Rebooting router didn't fix it
Problem is with all browsers and tracert command
08-12-2015 4:20 PM
08-12-2015 4:28 PM
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Jim>route print
Interface List
17...74 d4 35 bd 43 ad ......Realtek PCIe GBE Family Controller
1...........................Software Loopback Interface 1
16...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
15...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.102 10
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.102 266
192.168.1.102 255.255.255.255 On-link 192.168.1.102 266
192.168.1.255 255.255.255.255 On-link 192.168.1.102 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.102 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.102 266
This is from the XP diagnostics
Gateway DiagnosticComparing the two I see what you mean as this looks wrong
Gateway
info The following proxy configuration is being used by IE: Automatically Detect Settings:Enabled Automatic Configuration Script: Proxy Server: Proxy Bypass list:
info Could not get proxy settings via the Automatic Proxy Configuration mechanism
info This computer has the following default gateway entry(ies): 192.168.1.254
info This computer has the following IP address(es): 192.168.1.103
info The default gateway is in the same subnet as this computer
info The default gateway entry is a valid unicast address
info The default gateway address was resolved via ARP in 1 try(ies)
info The default gateway was unreachable via ICMP Ping
info The default gateway was not visible via TraceRoute
info TCP port 23 on host 192.168.1.254 could not be reached (Error code 0x274c)
info TCP port 80 on host 192.168.1.254 could not be reached (Error code 0x274c)
info TCP port 8000 on host 192.168.1.254 could not be reached (Error code 0x274c)
info TCP port 8080 on host 192.168.1.254 could not be reached (Error code 0x274c)
info TCP port 161 on host 192.168.1.254 could not be reached (Error code 0x274c)
info The default gateway was unreachable via TCP
warn The default gateway was unreachable via any method other than ARP. This may mean that the gateway is down and there is an ARP proxy or this may mean that the gateway is up but there is a firewall
warn Hostname www.microsoft.com could not be resolved (Error code 0x2afc). Could be either gateway or DNS issue
192.168.1.103 255.255.255.255 127.0.0.1 127.0.0.1 20 on XP
192.168.1.102 255.255.255.255 On-link 192.168.1.102 266 on Win 7
08-12-2015 4:44 PM
Removed the fixed IP address from the Billion 8800NL router
Rebooted computer and all now works
Re: No internet access on XP computer- HELP - Fixed but I don't know why
08-12-2015 4:50 PM
08-12-2015 5:31 PM
