No apps on tv
FIXED- Subscribe to RSS Feed
- Re: No apps on tv
- « Previous
- 1
- 2
- Next »
Re: No apps on tv
24-06-2018 7:47 AM
My guess is that this is another case of incorrect geolocation. The change to unlimited will have caused a PPPoE drop and ( possibly ) a new public IP to be assigned. I believe Sony check that the IP is a UK one to allow apps to work https://community.sony.co.uk/t5/other-tvs/bbc-iplayer-and-demand-5-apps/td-p/1740787
You can try the suggestions on that link,but the chances are that you will get a similar public IP.
Basically Sony are using an out of date geolocation database. There's a big thread relating to this problem with other sites but I can't find it at the moment. One solution is to request a static public IP , £5 one off charge, which is allocated from a different IP range
Re: No apps on tv
24-06-2018 8:12 AM
@MisterW You diagnosis is a possible reason but I think we first need to establish if the TV is connected to the local network. Just need to confirm that the network settings on the TV are sensible, i.e. there is a valid IP address and gateway.
Re: No apps on tv
24-06-2018 12:01 PM
@RealAleMadrid I'd agree with you , and it's probably worth checking anyway
but
Its the same router same TV... The on ly thing that changed was the upgrade to plusnet unlimited broadband
Re: No apps on tv
24-06-2018 12:28 PM
Well finally solved the problem.thank you all so much for your posts and help. what was the solution? Very complicated .... unplugged the TV's and plugged it in again. All apps back as if by magic.hope that you all have a great day.
Re: No apps on tv
24-06-2018 11:00 PM
- « Previous
- 1
- 2
- Next »
