No apps on tv
Whiteliner15
No apps on tv
Help required please.....pensioner neighbour a Plusnet neighbour recently upgraded to broadband unlimited.since the upgrade there are no apps on the Sony TV's whereas there were apps especially  Netflix...... before .trying to help I have hard wired from the router to the TV's to no avail.the router is her own and not a Plusnet one however it worked fine on her old contract with plusnet.however as it is not a Plusnet router the Plusnet support will not help. Can anyone advise thanks?
Fixes: 25
Re: No apps on tv
Perhaps the network IP address of the router (or "gateway") is hard-programmed into the TV settings?  If the new router had a different network IP address then the TV would not connect to the internet.  Most (all?) Plusnet routers have network IP address 192.168.1.254 .
Whiteliner15
Re: No apps on tv
Hi Reed thanks for your reply..... Its the same router same TV... The on ly thing that changed was the upgrade to plusnet unlimited broadband
nanotm
Re: No apps on tv
firstly has the router been switched off left for 20 minutes then switched back on ?
if it has then some clarifications required;
when you say changed to unlimited just to clarify did it change to/from a fibre (FTTC) service or was this a straight forward upgrade of adsl 8mb to adsl 33mb service ?
and was youview added into the mix or not ?
youview changes required setting in the router (and if you dont know what your doing then its simpler to use the plusnet hub router)
if you changed from adsl to fibre then settings need changing,
its possible that a router reset has been performed (paperclip into the factory defaults button) in which case nothing will work until the relevant details are re-added to the router (like account name password etc)
thats about the only things I can think of off the top of my head, and its been years since I changed my connection lol
Fixes: 5
Re: No apps on tv
Quick question, does everything else work OK and is it just the TV, or does other connected stuff not work. If it's just the TV, can you post up what ip address it's getting, and is it set to static or dhcp. Switching broadband product should not affect your internal network connectivity.
Whiteliner15
Re: No apps on tv
Thanks nanotym.......no fibre nor you view just updated to unlimited .there were apps before on TV's and access to Netflix but now no apps and no Netflix access
Whiteliner15
Re: No apps on tv
Thanks pencils.......it's just the TV's everything else is ok and broadband connection ok thanks
Fixes: 5
Re: No apps on tv
OK, so that narrows it down to the tv and suggests that Internet connectivity is not an issue. Was the TV originally connected wired or wireless. First thing I would do is reset the TV network settings, and then see if the ip address it's got correspond to the router ip range. What TV is it?Huh
Whiteliner15
Re: No apps on tv
Thanks.....its a reasonably new sony
Whiteliner15
Re: No apps on tv
And it was connected wireless however I connected a cable straight to the router but that didn't work
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
Fixes: 5
Re: No apps on tv
First off as I have said, check the ip address. If OK I would reset the network settings on the tv. What model of Sony... Some Samsung models failed if the Samsung portal was down.
Fixes: 538
Re: No apps on tv
Hi there.
Speaking completely from a personal POV as it seems their broadband connection is perfectly OK since it works on other devices, if you can post a photo of the setup of how the TV is connected to the router, this may help us offer more guidance.
Whiteliner15
Re: No apps on tv
Thanks gandalf........is that found by going into the router settings page on the desktop ..........or on the TV's settings
Fixes: 538
Re: No apps on tv
I’d imagine the settings on the TV.
Fixes: 5
Re: No apps on tv
What's the model of TV?? Can maybe help more knowing this. It's definitely the setting of the tv we need
