No admin password for windows repair
- Re: No admin password for windows repair
26-02-2008 4:22 PM
I'm trying to run repair from a windows XP disc and it asks me for Administrators password.
I know for sure that no password has ever been set for this computer and because I cant type in what it desires I can't advance
I tried typing "admin" and "password" but that doesnt work
Theres no way I can get anything from an administrator other than myself because I was the one who installed XP onto a blank hard drive in the first place
Could anyone please advise
2 REPLIES 2
26-02-2008 4:25 PM
If there really is no admin password then just pressing return should do it. If it does not allow that then there is an admin password set.
http://home.eunet.no/~pnordahl/ntpasswd/ explains how to get rid of any admin passwords.
29-02-2008 12:05 AM
When it was working what did you login as? This is what you need to login as for recovery. So if you had a username fred with no password that would be a admin.
Admin wouldnt work as the default is administrator not admin so try administrator and hit return
