No Wifi when adding second SIM to Realme phone
pieterv
As above. Wifi (as in home router's wifi) works fine with one SIM. Adding a second it doesn't.
Grateful for any ideas.
3 REPLIES 3
shutter
Fixes: 61
Re: No Wifi when adding second SIM to Realme phone
Try
Settings >Wireless & Networks> Dual SIM Settings .check on there for  all the settings for both SIM1 and SIM2
pieterv
Thanks, had already checked that.
RPMozley
Fixes: 10
Did you try swapping SIMs positions in the tray (or whatever SIMs are held in)?
Is the WiFi completely off in that scanning finds nothing or some other problem?
That's RPM to you!!
