Nikon View NX2 problem
morgan2476
I recently purchased a Nikon SLR Camera which I am really pleased with.  However, the software that came with it is useless.  Every time I try to open it I get the message - "ViewNX has stopped working."  I have tried every solution posted online, including, using the latest version, running as Administrator and downloading the latest version of Quicktime.  I am now reaching the time of desperation hoping thatt someone on the forum will be able to help.  I am running windows 7.
8 REPLIES 8
ReedRichards
Seasoned Pro
Fixes: 25
Re: Nikon View NX2 problem
Did you install the 32-bit or the 64-bit version?
morgan2476
32 bit.  It is Win 7 32 bit that is insyalled.
sjptd
I don't know that software specifically, but generally software that comes with cameras etc is fair average rubbish.
You will probably be better off with good free offerings such as Raw Therapee (http://www.rawtherapee.com/) for processing and Picasa (http://picasa.google.com/) for management.
ReedRichards
Seasoned Pro
Fixes: 25
Okay, that's unusual - most Windows 7 computers run the 64-bit version.  Did you really install viewnx2 but get an error message about viewnx or is that a typo?
There is some sort of Nikon cleanup utlity to wipe the slate completely clean and start again after you have uninstalled software.  Here, I think http://nikonasia-en.custhelp.com/app/answers/detail/a_id/7361/~/regsweeper2---registry-key-deletion-...
morgan2476
I am assuming it is 32 bit.  How do I find out.
morgan2476
I think I will give this Raw Therapee a try.
Oldjim
Fixes: 63
The easy way to find out if it is 32bit or 64bit is too look in the C: drive
Do you have two folders Program Files and Program Files (x86) if you have it is the 64 bit version
morgan2476
No it is just program files.  I checked by  right clicking "My Computer."
