Nexus 7 - pin lock corruption?
CX
I can't believe this.
My Nexus 7 has just decided that it doesn't like my lock screen PIN (all I get is "Wrong PIN"). The PIN was set months ago, and I haven't changed it - in fact, I entered it without issue literally 5 minutes before it all went wrong (and it's been entered so many times that it's in my muscle memory!). Literally the only thing I did was connect up my Bluetooth keyboard (which I haven't used for a while), went away to make a coffee, came back, tried to enter the PIN on the Bluetooth keyboard and it failed. Figuring I must have typed it wrong, I tried again, "Wrong PIN". Tried on the on-screen keypad - "Wrong PIN".
To top it all off, I don't get offered any chance of resetting the PIN - just 30 second delays every 5 failed attempts. Rebooting didn't help.
4 REPLIES 4
DaveyH
Champion
Fixes: 12
Re: Nexus 7 - pin lock corruption?
If you keep entering it, (may have to do it half a dozen times or so) eventually it will give you the option to sign in with your Google login .
CX
Thanks. By all accounts It should do that, but it isn't. Now up to 105 attempts, according to the on screen message.
Edit: I ended up doing a factory reset. Good job there wasn't anything on the tablet that isn't stored elsewhere.
VileReynard
Fixes: 20
You were lucky it isn't a Nexus 6.  Grin Grin Grin
DaveyH
Champion
Fixes: 12
Quote from: CX
Strange, that worked for me in the past.
Edit, appears it only works if WiFi is enabled, which I guess makes sense since i presume it would have to authenticate with googles servers.
