Nextchip NVP1104B driver
- Nextchip NVP1104B driver
28-02-2013 2:57 PM
dose anyone have a CCTV card with Nextchip NVP1104B driver?
trying to find the driver on the net and its like getting blood from a stone...
4 REPLIES 4
Re: Nextchip NVP1104B driver
28-02-2013 9:32 PM
I think the Nextchip NVP1104B isn't the main chip that you need a driver for.
PCI cards are identified by a vendor id and device id number, both 4 hex digits, you should be able to find them in the properties of the device in device manager.
01-03-2013 11:38 AM
its a cinesse card ... so gives me crap info i did how ever manage to install some drivers that seem to work but i dont get a display when i open up the DVR center... so spend some time looking for a fix for this
any ideas?
any ideas?
01-03-2013 1:13 PM
Either the drivers you found don't actually work with your cctv card, or some issue with your graphics card / graphics drivers or possibly even video codecs.
01-03-2013 8:49 PM
sorry about swear word.....
and im guessing its either the driver im using or the software to try and view the cams
heres a link to the card i have
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330780743754&ssPageName=ADME:X:RTQ:GB:1123
i have tried to contact the seller for him to give me the web link for the software that he gave me before but im having no joy....
i ran aida 64 and got it to give me a report.... the report came back telling me it was JVS-C790 multimedia card
so i downloaded and installed JVS-C790 software drivers installed no problems but no image
If anyone knows any driers and software for this card plz letme know
