New wirless router Advise
- Re: New wirless router Advise
18-02-2009 7:50 PM
I think I posted this in the wrong forum under Hardware so I've posted here instead. By the looks of it the julesandsand topic is what I'm afraid of, someone using my bandwidth.I've found since posting a section on password changing but I'm unsure which password I'm supposed to change so I've left alone for now.
Hi, I have just received the Thompson Wireless router model TG 585V7 and because its the first Wireless Router I've had I read the Wireless security guide online at Plusnet Help site, it mentions switching off the SSID broadcast for extra security, the trouble is I cannot find it, could anyone advise please, I have set the Router up as per instructions that have come with the router and i am using the WPA number.
Also With my old BT voyager 210 I could check the line stats but I cant see those on this one, I check them every so often just to make sure they are OK.
regards
jono
regards
jono
8 REPLIES 8
18-02-2009 7:51 PM
If you read more recent stuff, especially related to Vista, you won't bother hiding the SSID.
18-02-2009 8:00 PM
jim:post I have deleted the other thread mod:end
18-02-2009 8:09 PM
Hiding the SSID doesn't help security.
Make sure you have WPA encrytion (not WEP).
18-02-2009 8:17 PM
Hi, I'm running Vista SP1 with intrusion detection enabled and Remote Asistance disabled, User Management is Administrator, that's the part I'm confused about, I did not put any info in for administrator, all i filled in was my log on info for plus net and the WPA number, I'm running Norton Internet Security 2009 as well and it says I'm protected. Do I need to set any other settings up at all or am i set up by default, I noticed in the post I mentioned above that his security was not sufficient.
regards
jono
regards
jono
18-02-2009 8:18 PM
Hi me again, Thanks for deleting the other post by the way Jim
18-02-2009 11:32 PM
If you think someone is stealing your bandwidth it is nothing to do with your pc it will be your router. If the router is open or poorly protected then anyone can connect to it and download using your account.
There should be somewhere on the router that show whos connected and you should check this regular if you suspect problems.
You can set your router to only let people with a certain MAC address in and you assign your MAC address so know one else can get in. This can be spoofed but it can be harder to do
19-02-2009 12:39 AM
Although all of the security methods can be broken it's like burglars wandering down the street - it will be the ones with the open windows they break in to, not the ones which are all shut tight with security locks.
19-02-2009 8:41 AM
I think that if you use WPA2 with an unguessable password you should be OK. I changed my Belkin router because the DHCP client list displayed nothing, I don't know if the bandwith thief had done this or it was a Belkin software fault, I suspect the latter.
