New scam BSOD
rongtw
Fixes: 12
New scam BSOD
A bit of a warning, there's a new type of malware out on the loose that actually fakes a BSOD and then makes you purchase ‘Windows Defender Essentials’ to solve these blue screens of death..Angry
https://forums.malwarebytes.com/topic/215749-removal-instructions-for-troubleshooter/
8 REPLIES 8
Pete11
Seasoned Pro
Fixes: 4
Re: New scam BSOD
I was just about to post about the same thing. I'm glad there's people out there that finds these things and posts how to fix 'em.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Alex
Fixes: 13
Re: New scam BSOD
Yep thanks, since viruses first came about, people liked the thrill of ruining your computer.
Now (in this era) people have worked that they can do that and also make money too, it will only get worse.
shutter
Fixes: 65
Re: New scam BSOD
Thanks for the advanced warning... Have "bookmarked" the removal page, as there is quite a lot of steps to take , after running Malwarebytes..
As my bookmarks are "sync`d" using Xmarks, the page will be on my other laptop, if/when I need it.....
ReedRichards
Seasoned Pro
Fixes: 25
Re: New scam BSOD
System Restore is the best means of removing malware if it will run successfully.  That is because it will revert any changes to your settings that were made by the malware as well as getting rid of it.  In Windows 8/10 the best starting point is by restarting the computer whilst holding down the Shift key.  System Restore will fail if you are still on the 1607 version of Windows 10 (but there is a workaround).
VileReynard
Fixes: 20
Re: New scam BSOD
You used to be able to install a BSOD as a screensaver.
Someone did this to me whilst I was at lunch, in the days of NT4.
I had to be restrained from rebooting it.
Legend
Fixes: 254
Re: New scam BSOD
@VileReynard So you didn't want to 'boot' the culprit?
sparkrace12
Re: New scam BSOD
A virus I had last year locked my computer up, and when I eventually tried to get system restore to run, it would and then on restart the dam virus got into that and messed everything up.
took laptop to my local computer shop, and they used some program disk and were able to get some stuff back, but unfortunately I lost countless files & photos, so had the harddrive completely cleaned.
yes I can hear my daughter saying dad you should of backed everything up., hard lesson
sparkrace22
billnotben
Re: New scam BSOD
@VileReynard wrote:
install a BSOD
Back in the days of windows 95, when BSOD, was often a regular occurrence, there was a lot of jokey programs about. One was of course the BSOD. Had many a laugh with it loading it on friends and rellies PC's.
Nowadays next to no one would trust any programs like this. It's a shame in some ways.
