New m/b time help needed
- New m/b time help needed
- « Previous
- Next »
Re: New m/b time help needed
23-02-2015 7:30 PM
and is the gt-610 an asus card ?
having done a quick search on the gt610 cards it seems that a defective vga output was / is a common problem with them, hopefully your new choice of card will be up to the task
24-02-2015 9:51 AM
Since at the mo, the only things in the box are a br burner & a hdd and an ssd it shouldn't be stressed.
24-02-2015 10:02 AM
I say this because that would obviously eliminate the monitor as being the problem, of course if the problem transfers across monitors then it would indicate that the board output was faulty /
I'd still look at going down the xfire /sli route if you want to use multiple monitors using mixing different gfx could easily be causing the problem and those on board units are never up to much
btw as a side note I upgraded an old pc (phenom II x6 1055t/ asus-m4a89td pro/usb3 +16GB Kingston CL9 1333 ram) to asus-sabertooth 990fxR2.0 /amd fx-8350/8GB corsair vengeance 1866ram
the difference is quite staggering (I just swapped out the parts and reactivated existing windows install) now I can handbrake in 5 mins instead of 15 mins on a standard 5gb mkv file ......
and there's a noticeable performance improvement in gaming
although I kept the same gfx card, (sapphire R9-270x 2gb)
24-02-2015 10:20 AM
Have switched them over and the issue moves, so vga port issue.
Hopefully the new card will fix these errors. And allow me to play some games again.
IF I had the money then yes a nice shiny m/b with 16Gb of oc ram & a crossfire setup would be great, but I am already 50% over my meagre budget. (sounds like a government project!)
24-02-2015 1:52 PM
24-02-2015 1:59 PM
Quote from: Hairy but I am already 50% over my meagre budget. (sounds like a government project!)
well when asked you can say you used the governments tried and test financial formula for budgetary matters and feel like you have achieved the best value outcome particularly given the shifting goal posts and projected lifespan of the new equipment despite not achieving initial financial goals you have however achieved the best overall end point (just make sure its insured for when the grandkids tip juice in the back of it whilst your busy on the forums)
of course for maximum delivery its best at this point for the relative equipment to start smoking /hissing and then either emit a loud bang or burst into flames
24-02-2015 2:41 PM
My android tv box doesn't like mp4 in high format, so need to convert to mkv's in normal.
24-02-2015 2:54 PM
24-02-2015 3:27 PM
24-02-2015 3:41 PM
most of the devices round the house can then view them from usb drives /card readers and play them back, only 3 junk TV's struggle with it but there all connected to other stuff that can handle the process like an xbox360 so its all good from my viewpoint
only thing I don't like about handbrake is all the log files it creates reducing its operating time, I have to delete them or it can take up to a minute for the source /save selections to be actioned .....
no idea why it creates the files though but there damn big (last list was 3 gig in size from about 45 movies) strange ness....
24-02-2015 3:48 PM
Or ffmpeg depending on whether it is a movie or a tv short (ffmpeg for tv stuff hb for the movies)
24-02-2015 3:53 PM
is where I find them
24-02-2015 4:10 PM
On Linux & cli
Log data is output to Standard Error
in the gui
it is saved in .config/ghb (just where I thought I would find it NOT).
Checked and there are some old logs there, so time to add a cron job to delete them.
24-02-2015 5:34 PM
They are very small logs anyway.
About 10K each.
25-02-2015 4:21 PM
- « Previous
- Next »
