New download speed test site
- Re: New download speed test site
20-05-2016 9:11 AM
Yet another speed test site but this one is brought to you by Netflix. Yes the TV streaming site has create a quick speed test using their own delivery servers.
It doesn't use Flash or any add-ons but does run as soon as the web page loads. There is no interaction with you. And it is quick to run.
Try it at https://fast.com
20-05-2016 9:33 AM
One here too (just for comparison):
http://www.thinkbroadband.com/news/7425-20-seconds-spare-run-a-speed-test.html
20-05-2016 9:38 AM - edited 20-05-2016 9:39 AM
That's too slow , 20 seconds is way too long to wait. The Netflix one is 7 seconds on my PC.
Yes I've tried that TTB quicky one but prefer their Flash based on as I like the x1 and x6 testing which highlights gateway issues for me.
And yes the Netflix speed results are consistent with TTB.
20-05-2016 12:35 PM
Just done two tests on each of those,,.... both give about the same result... 5.4 Mbps whereas my Routerstats is showing 6.655
I am on a Wireless connection about 18 inches below the router... ! Router is the Technicolour 582... It would probably gain a bit more if I used the cable connection to the router....
20-05-2016 2:02 PM
Tried a test on it & shows 38 MBPS,which is about right.
20-05-2016 10:59 PM - edited 20-05-2016 11:00 PM
Still locked at 34 Mbit on my crippled infinity 2 BT... EFFING BT!
I really hope, come Monday, PlusNets will deliver at least the 45 I was getting 2 months ago on BT (they've lot a happy 5 year customer over this!)
22-05-2016 1:41 PM - edited 22-05-2016 1:42 PM
3.3Mbps
I reckon we'd get faster speeds on ADSL again rather than this fibre malarky that is now delivery slower than ever speeds. Heck... probably best to tether to my mobile.. tesco will deliver at 18Mbps...
EDIT: That said, the second test came back better... at 19Mbps....
22-05-2016 2:36 PM - edited 22-05-2016 4:02 PM
It was actually by using this site that I realised I had an issue with one of my connections.
So with a bit of luck that will get resolved tomorrow.
22-05-2016 3:51 PM - edited 22-05-2016 3:53 PM
Plusnet on Monday, 23rd...
Plusnet better be a damn sight faster or I'm cancelling the contract!
22-05-2016 8:14 PM
Fast has me as 68mb, TBB 67mb. I'm not arguing about a mb.
Lately though I have been creeping up on speed. Was about 65mb but now seeing 72-74mb/s on TBB x6 burst
23-05-2016 4:36 PM
Plusnet is now active and the first speed test shows 46 MBit - faster than the 4 year BT speed!
It ranges, depending on speedtest, from 43 to 46 - on the same line as BT's ****** 33 MBit.
Keep it up PNet and you'll have a long term happy customer!
26-05-2016 8:45 AM
This is my favourite – more technical info, and flash-free:
