New development language from Sun
New development language from Sun Java FX which is set to rival flash and silverlight free from
http://www.javafx.com/
looks interesting and its free which must be the best bit. There are tutors online and demos. You can build an aplication for a web page which can be dragged onto a desktop and run
Midnight_Caller
Re: New development language from Sun
The link is broken.
VileReynard
Seasoned Pro
Fixes: 9
Java is required to run JavaFX applications.
You will now be redirected to a Java update site to get the latest version
So it's a bit of a non-starter - unless you want to wait whilst Java grinds into action.
