New computer monitor
- Re: New computer monitor
21-10-2011 11:31 PM
What type of monitor would suit me best? If you need any other information, just ask. I'm not sure what else would dictate what monitor to get.
Cheers.
22-10-2011 12:03 AM
22-10-2011 1:44 PM
If you think your monitor might outlast your computer then you might want one with an HDMI input as well as the VGA input I imagine you will use.
Remember that if you buy, say, a 22" monitor with full HD 1920x1080 pixel resolution then for best results you need to run it at that resolution so all your icons and default fonts will appear quite small. That's not good for anyone with poor eyesight.
22-10-2011 2:20 PM
Have a look on here for comparisons http://www.digitalversus.com/
22-10-2011 2:49 PM
http://www.misco.co.uk/?ssid=-1
22-10-2011 4:29 PM
Be aware that a lot of the very cheap monitors lack DVI or HDMI input, which means you will have to use VGA. This is fine, but a lot of VGA cables, and graphics cards DAC, are inadequate for handling the bandwidth that 1080p requires and the result will be a shadowy, smeary or blurry mess which also requires recalibrating from time to time. Get a monitor with DVI and you should be fine.
In terms of the panels themselves there are various technologies. Pretty much any 'regular' monitor is going to have a TN panel, but there is also IPS and PVA (and sub-types of them). The benefit of TN is that is cheaper and can give good response times, the downside is reduced viewing angles. The viewing angle problem isn't that significant these days though - I use a modern TN monitor at work and the viewing angles are acceptable. IPS and PVA tend to be much more expensive.
Backlights - LED is the way forward for sure. You're less likely to get annoying hum when reducing the brightness, the power consumption will be lower and longevity is potentially better.
22-10-2011 5:38 PM
If you ever decide to get into photo or video editing you will sincerely benefit from the extra size.
I have a 26" 16:10 llyama which really is a delight to use.
Forum Moderator and Customer
22-10-2011 6:39 PM
Having a high vertical resolution is also very useful for getting more on your screen when viewing long websites such as eBay, so you feel less like you are browsing the site through a letterbox.
It would be worth finding out what the maximum capability of your PCs graphics adaptor is, and then using that as a minimum specification for the monitor.
25-10-2011 9:17 PM
So, I should look for one that's:
LED Backlighting
HDMI and VGA input (or DVI?)
Good response time
1920x1080 resolution minimum (possibly 1200 min for height?)
At least 21/22/23 inches (size will have a limit, unless I get a new table too, already have a decent size TV on it)
TN panel generally cheaper?
And suggested sites to buy from are: Misco and ebuyer.
In reply to the last post, my graphics card is an ATI Radeon HD 4300/4500 if that makes a significant difference to the above that I should look for.
Again, thanks for the help and I shall start looking!
25-10-2011 9:49 PM
Quote from: Cefca And suggested sites to buy from are: Misco and ebuyer.
Two other good sites are Novatech and Aria. I have purchased from both and never had any problems. Even purchased a 22" monitor for SWMBO from Aria by mistake when I really wanted a 23". A quick call and they said to reject the monitor when it is delivered. Meanwhile they sent the required one out and no return charge. Refund was given within a few days
25-10-2011 10:33 PM
Looked a pretty good deal to me.
26-10-2011 8:56 PM
Cheers by the way jelv.
26-10-2011 10:23 PM
Response time seems to be a pointless figure with flat screens.
27-10-2011 8:10 AM
Nice low power consumption too (41W) - my 24" Dell can't get that low even on minimum brightness, all for a similar resolution.
