New Vodafone "Sure Signal"
- Re: New Vodafone "Sure Signal"
24-01-2010 7:42 PM
Hi Everyone,
This is pretty much addressed to anyone on these forums who has recently bought the Vodafone Sure Signal. In brief, I had to purchase one of these little miracle workers, as I have just moved house, and found to my dismay that the mobile phone signal was so poor I was unable to use it at all. The idea of this box of tricks is to boost a 3G signal around the household, however, for some reason, the Sure Signal will not configure itself to the router supplied by Plusnet (white Speedtouch) but will with a spare Netgear DG834GT I have. I wonder if any of you have come across a similar issue? If so, I would be glad to hear any pieces of wisdom.
Thanks in advance,
Jenkers.
Thanks in advance,
Jenkers.
5 REPLIES 5
24-01-2010 7:57 PM
Moved to this forum as it looks to be the correct place given that this unit connects using the router ethernet post
24-01-2010 7:58 PM
Which Speedtouch router is it - many of them are white - if new I assume it is a Thomson 585
25-01-2010 8:35 AM
Just had a bit of a google and it appears that the Sure Signal ( used to be called Access Gateway ) makes a VPN connection via your router to the Vodafone servers. There is a problem with the latest TG585v7 router f/w and VPN, see this thread http://community.plus.net/forum/index.php/topic,82852.0.html. Try downgrading the firmware on the TG585 to Version 7 as detailed in ths libray article http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
25-01-2010 10:56 AM
There's one of these beauties behind my desk at work. No problems with it but it is plugged into a 2Wire 1800HG and not a 585v7. I'd be interested to know whether or not the PPTP removal from the version 8 Thomson firmware causes issues because if it does the guys on the helpdesk would probably be keen to know.
As far as I know the femtocell boxes use IPSec and not PPTP.
@Jenkers, try downgrading to the version 7 firmware as per the Community Library article I wrote and let me know how you get on...
26-01-2010 12:26 PM
FYI. Will be getting one of these connected when I return from a business trip in two weeks time, it will be connected to a DG834Gv2.
I am on BBYW1 so should this work or is the Ellanoya throttling the IPSec data too much on that account type?
How much data does it send/receive on days when there are no calls?
3Mb FTTC
3Mb FTTC
