New Sky viewing cards for BT Sport
- New Sky viewing cards for BT Sport
02-09-2014 10:45 PM
Considering getting a 2nd hand/refurbished Sky+HD Box (latest black type) off eBay to get BT Sport HD via Plusnet - but before I take the plunge could anyone please answer my questions below:
1. Is there a charge for the new viewing card provided via Plusnet? (Obviously I'm not currently a Sky customer/subscriber)
2. Are there likely to be any compatibility issues pairing a new card with a 2nd hand/refurbished Sky+ HD Box?
3. Without a Sky TV subscription will I be able to record BT Sport channels ( or any FTA channels) on the Sky+HD Box?
4. If answer to 3. is no, does that mean I only need to hook up a single LNB channel to the Sky+ HD Box (as a single channel player only)?
Thanks....
Thanks....
8 REPLIES 8
Re: New Sky viewing cards for BT Sport
02-09-2014 11:20 PM
Quote from: Washy1
No
Quote 2. Are there likely to be any compatibility issues pairing a new card with a 2nd hand/refurbished Sky+ HD Box?
No
Quote 3. Without a Sky TV subscription will I be able to record BT Sport channels ( or any FTA channels) on the Sky+HD Box?
No
Quote 4. If answer to 3. is no, does that mean I only need to hook up a single LNB channel to the Sky+ HD Box (as a single channel player only)?
Yes. But you'll need to enable single feed mode or it will nag you with no sat signal error messages.
03-09-2014 9:32 AM
Beat me to it Davey.
Washy, let me know if you want to place an order and I'll get you a viewing card dispatched ASAP for you.
03-09-2014 8:43 PM
Thanks DaveyH - it's good to know for sure. Good tip on single feed mode, that would have been annoying.
MattyC - thanks also, I haven't bought the Sky+HD Box yet so I'll order BT Sport as soon as I have. To save any delays my end, if you're able to order a viewing card in advance ahead of my order and any Sky Box S/N or such info then yes, please go ahead.
Got another question now...., would I need to connect the Sky+HD Box to the internet for any reason? If so, would wireless be good enough or is Ethernet cable recommended?
Many thanks
Many thanks
04-09-2014 10:16 AM
The dispatch of the card is part of the order placement process, so it would probably be best to wait until you have your Sky+HD Box.
As far as I can tell, I don't think you will need to be connected to the internet for the BT Sport service.
04-09-2014 7:56 PM
MattyC, would you please confirm for certain whether an internet connection is required for BT Sport HD from Plusnet ?
Thx
Thx
05-09-2014 1:32 PM
Sorry for the slow response, Washy.
I've just checked with one of the staff dealing with BT Sport and they can confirm that it is not require.
Hope this helps.
Hope this helps.
05-09-2014 4:29 PM
have tried to ring customer support line but have given up after no answer in 30 minutes.
If i took bt sport and needed plusnet to send me a card, how much would this card cost.
05-09-2014 4:31 PM
Answered in the other thread you hijacked...
Google terms 'plusnet bt sport' seemed to work for me
