New Plusnet router connected devices
- New Plusnet router connected devices
26-07-2015 1:07 AM
Is it right that the plusnet router I have doesnt show ANY connected devices over wifi and only shows devices connected by ethernet?
There isnt even a DHCP table, which would really help..
Is there any way to change the firmware for something that adds these feature/s?
6 REPLIES 6
Re: New Plusnet router connected devices
26-07-2015 3:19 PM
It depends on your router - but it won't show devices which haven't been switched on recently.
26-07-2015 7:05 PM
Its the latest plusnet router.
I know there are a few devices connected via wifi but they just dont show in the connected devices, and no dhcp table to look either.. bit basic really 😕
26-07-2015 7:53 PM
You could write a little script which pings all possible devices in your DHCP range...
(and displays the hits).
or get a proper router.
26-07-2015 7:56 PM
Ignore foxy's sarcasm createdbydan
Login as http://192.168.1.254/expert_user.html you'll find a bit more there that may be of some use. The list on the Homepage is useless
26-07-2015 7:58 PM
Also have a read of the quite a few 2704n threads on this board. You'll find a few that may be helpful if you are into playing with the config a bit. But I wouldn't go messing with Firmware unless you are confident in what you are doing in case you brick it.
28-07-2015 1:59 AM
Quote from: Anotherone Ignore foxy's sarcasm createdbydan
You sir are a legend!
