New Customet awaiting BT Voyager 2091 - Question
Jbo82
Hi guys, I'm new to Plusnet and have to say I have found them very good so far. I ordered the broadband only last week, and the line has been activated today and the Wireless Router also came today. I am currently at sea and my partner is going to get the router set up after work. Just a quick question, as we have had the BT Voyager 2091 from Plusnet, will it just be a case of connecting the router to the line and away we go or will the router need total setup from scratch?
thanks,
James.
itsme
Re: New Customet awaiting BT Voyager 2091 - Question
Needs to be setup information how to can be found here
Jbo82
thank you very much for that, seems very straight forward.
Cant wait for it to be up and running.
Thank you
