New Customet awaiting BT Voyager 2091 - Question
- New Customet awaiting BT Voyager 2091 - Question
26-08-2008 6:17 PM
Hi guys, I'm new to Plusnet and have to say I have found them very good so far. I ordered the broadband only last week, and the line has been activated today and the Wireless Router also came today. I am currently at sea and my partner is going to get the router set up after work. Just a quick question, as we have had the BT Voyager 2091 from Plusnet, will it just be a case of connecting the router to the line and away we go or will the router need total setup from scratch?
thanks,
James.
thanks,
James.
2 REPLIES 2
Re: New Customet awaiting BT Voyager 2091 - Question
26-08-2008 6:35 PM
Needs to be setup information how to can be found here
26-08-2008 6:42 PM
thank you very much for that, seems very straight forward.
Cant wait for it to be up and running.
Thank you
Thank you
