New Computer Internet Problem
- New Computer Internet Problem
24-06-2020 8:18 PM
I have factory reset my computer and reinstalled Windows XP (I know!) My wireless connection says I’m connected to Plusnet and I can download XP updates. However, when I click on internet explorer and try to browse the internet I get error messages saying there are connection issues. Any ideas?
Thanks in advance
Re: New Computer Internet Problem
24-06-2020 10:00 PM
This topic has been moved from ADSL Broadband to Tech Help.
24-06-2020 10:13 PM
Has Internet Exploder updated itself to the latest version?
Even though the latest version is now unsupported, ISTR that older versions will be prevented from connecting because of security vulnerabilities.
25-06-2020 1:15 AM
You don't have any anti-virus sofware blocking outgoing traffic?
Can you press, Ctrl-A, and type 'cmd'.
Then type 'ipconfig /all' on the DOS prompt and post the results, remove any personal details. There shouldn't be any other than your network name.
25-06-2020 8:38 AM
When I try to access any website it says “there is a problem with this website’s security certificate”. I don’t have any anti virus installed yet as not able to download anything other than windows updates.
25-06-2020 9:39 AM - edited 25-06-2020 9:50 AM
Just thoughts? Why did you do a reset in the first place? Were you having problems already?
And XP is getting pretty old. I know we still use W95 (and even OS's that predate that) in the factory but they are machines that never go online. I'd be looking at other ways. Linux, upgrades or even running VM. Currently you have a massive security hole just waiting to be filled with malware.
Edit: And I doubt if you would have the 'latest' version of IE as from the table it doesn't support XP
Windows operating system | Latest version of Internet Explorer | Release Date |
Windows 10* | Internet Explorer 11.0 | 2019-12-10 |
Windows 8.1, Windows RT 8.1 | Internet Explorer 11.0 | 2019-12-10 |
Windows 8, Windows RT | Internet Explorer 10.0 - Unsupported | 2016-12-13 |
Windows 7 | Internet Explorer 11.0 - Unsupported | 2019-12-10 |
Windows Vista | Internet Explorer 9.0 - Unsupported | 2011-03-14 |
Windows XP | Internet Explorer 8.0 - Unsupported | 2009-03-19 |
25-06-2020 9:43 AM
If this is the message you are getting @Chardster check your PC is set to the correct date and time. I suspect it's not.
26-06-2020 5:47 PM - edited 26-06-2020 5:48 PM
seconded - check the system's time. This is often the cause of problems since the computer is out of sync with the world and gets its underwear in a twist. The wrong time is also a symptom of the motherboard battery being on the way out due to the internal time being lost when you remove power.
Mike
26-06-2020 6:28 PM
The mother board battery is normally just a CR2032 which is relatively cheap to buy only a pound or so Panasonic are a good buy
HD
26-06-2020 7:02 PM - edited 26-06-2020 7:03 PM
Another reason with IE is the old version does not support the current security protocols, which many sites now block browsers trying to use things link SSL 1, 2 or even 3 and TLS 1 or 1.1, most sites seem to now only support TLS 1.2 and 1.3 for secure sites, obviously this will depend on the site you try and visit.
But XP is simply dangerous to use on the Internet nowadays.
26-06-2020 9:47 PM
Mike
Or it's just because it's new. When I bought my last computer (Dell from Argos, made in China) the first message to appear on the screen after I'd set it up was, "It's 9.30 a.m. and temperature in Austin Texas is 21 C." Not something I needed to know but at least it alerted me to the fact that the clock was set to a time zone I wasn't in. I hadn't tried to do anything on the computer yet so I can't say if it would have caused problems.
26-06-2020 10:32 PM
26-06-2020 11:05 PM
27-06-2020 11:17 AM
27-06-2020 11:53 AM
I take it you are aware that Windows 7 support finished in Jan 2020. So probably not a good idea trying to buy it to be honest.
Your issues appear to be related to your computer now having out of date security protocol as I mentioned earlier in this thread.
How are you accessing these forums if you have no internet access? If this is another computer you might be able to download the exe file for another browser and then transfer it to your XP Computer.
But to be honest you are better forgetting XP for an internet access as far too high risk. This is by the way nothing whatsoever to do with PlusNet
