New 500GB hard drive - 2.5" or 3.5"
- Re: New 500GB hard drive - 2.5" or 3.5"
08-02-2013 10:51 AM
I have partially (temporarily) fixed it running Chkdsk and defragging the drive but it looking at the drive capacity it is nearly full so a new drive is needed
It is a long time since I bought a new hard drive but I was surprised to find that 2.5" plus adapter is about the same price as 3.5" for a 500GB drive (the existing one is 200GB)
Given that the main requirement, other than reliability, is quietness is there any advantage either way
08-02-2013 11:37 AM
08-02-2013 11:47 AM
08-02-2013 11:54 AM
You may get a 2.5" to 3.5" adapter with it, if not they're pretty cheap - not needed though if the case has somewhere you can mount it or you're happy to just blu-tack it to the case somewhere
Oh, bear in mind if they're PATA rather than SATA it's a different ribbon cable to fit it (though I'd be surprised these days if it was PATA).
08-02-2013 12:02 PM
I will have a look at is the space in the case as I may have to install the new drive in a 5.25" slot which will be messy
One thing I may well be doing is fitting the new drive, partition it to 50GB/450GB then mirror the existing XP partition to the 50GB partition in the new new drive and the existing programs and data to the 450GB partition then change the boot order to use the new drive as a primary with the old drive as a backup store only
08-02-2013 4:08 PM
08-02-2013 8:09 PM
"Fitting" was by two pieces of self-adhesive velcro tape.
08-02-2013 8:22 PM
08-02-2013 8:47 PM
Quote from: Oldjim SSD isn't an option - the motherboard doesn't support it
Why would your motherboard not support it? If it can handle sata2 then there are some very reasonably priced sata2 ssd drives around. Move the OS, Programs and page file to the SSD and away you go.
If not then why go for a 500GB disk? They are nearly as expensive as 1TB ones? You can never have too much storage. Storage is a bit like space... detritus expands to fill it
08-02-2013 9:23 PM
However there are two problems
First - it looks like the drive may be having problems so replacing the whole thing would be advisable
The present OS partition is only 20GB which is now struggling
The other 180GB partition for programmes and data is also struggling with less than 10% spare capacity
Using an SSD for the operating system would still require an new hard drive for the extra capacity and the security
Why don't I look at a 1TB drive - first the extra capacity would be wasted and second it would increase the cost by about 50% (I am a mean person :-X)
08-02-2013 10:11 PM
08-02-2013 10:18 PM
08-02-2013 10:20 PM
08-02-2013 10:27 PM
EDIT - I see that Western Digital have a free Acronis version which does all that
09-02-2013 10:32 AM
Current trends in the IT rumourmill are to avoid Seagate at all costs. Also avoid Samsung as they are actually Seagate drives now .......
A lot of people don't realise that 2.5" SATA drives will happily plug into the same cables as a 3.5" SATA hard drive - the connectors are identical, it's just the mounting that is different.
I've always found 3.5" hard drives to have faster data transfer rates than the 2.5" drive although the 2.5" drives are more resistant to shock.
