Network
morgan2476
Network
Dear All
I recently received a Thomson router from Plusnet and everything is ok.  But I am now trying to set up a wireless network with my laptop using a usb wireless adapter.  It is not working - I am getting the message on the laptop - "limited or no connectivity".  Could someone give me a proceedure for sorting this out.  Thanks
Fixes: 117
Re: Network
Hi, does sound like an incorrect password has been entered when you connected to the router.
The password should be on the bottom of the router, it will be case sensitive.
Will Moderate For Thanks
morgan2476
Re: Network
Thanks  problem solved.  I did not think it was case sensitive.
Fixes: 117
Re: Network
Glad you've got it sorted  Smiley
