Network link aggregation
markmalley01
Hi All
Does the new type plusnet router support link aggregation (i rather doubt it but you never know)
The Traffic going in and out of my new home brew NAS (OMV Based) can saturate my Gbit network so I am thinking about using a twin aggregated link for more bandwidth.
The NAS will support it but I was wondering if the router does ?
If not I can always get a small managed switch to replace my unmanaged one quite cheaply loads of good second user ones available.
Best Regards Mark
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 60
Re: Network link aggregation
If you are referring to the Hub One then unfortunately not.
VileReynard
Fixes: 20
I use a simple unmanaged Gigabit switch connected to the router. The router can still provide DHCP & DNS (and internet access).
markmalley01
Hi There
Yes that's what I do so I will need a small managed switch instead of the dumb one which supports LACP
Best Regards Mark
