Netscape Navigator - RIP
jelv
Fixes: 10
http://news.bbc.co.uk/1/hi/technology/7163547.stm
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
15 REPLIES 15
AWB70
Re: Netscape Navigator - RIP
Never tried it myself, I've gone back to IE after mozilla was playing up.
Maybe because Netscape was in bed with AOL I know when I first started with PC's everyone said avoid them at all costs as it took over your machine.
petlew
Used to use Netscape before it got into bed with AOL, with Win 95 I think, was pretty good in those days as well, much better and more reliable than IE. Still got one of their coffee mugs around somewhere.
VileReynard
Fixes: 20
I first used Netscape on Windows 3.1 dialup  Grin
Kelly
Fixes: 9
Pah.
Give me Mosaic any day....
Kelly Dorset
Ex-Broadband Service Manager
7up
Fixes: 17
I used Netscape years ago too. It was in the days of IE v4.
When IE5 came out, Netscape was waaaaaay faster than the sluggish IE5. IE6 got worse still as clicking the back button seemed to introduce an annoying habit of the browser refreshing instead of simply going back to it's own cached version.
Netscape was a superior browser and the last version i tried a few months ago put it in competition with firefox but it just didn't really appeal to me as much as it used to.
Firefox is far from appealing with its memory eating bug. I've frequently found it chewing its way through 400MB of ram so I gave up on the mozilla based browsers and went back to IE which despite its faults doesn't try to hang my system randomly (it just crashes instead but leaves my OS running).
VileReynard
Fixes: 20
I've never seen FireFox using a lot of memory - certainly not enough for it to crash. I suppose if you had loaded a lot of badly written FireFox extensions it would be possible.
How much memory does IE use - M$ are renowned for their resource-hungry software.
Kelly
Fixes: 9
Nope.  Firefox eats memory for me too Cheesy
http://www.computerworld.com/softwaretopics/software/apps/story/0,10801,111065,00.html
Kelly Dorset
I did try FF a while ago after being persuaded by folks on the PN Portal forums, I also experienced the memory eating problems.
I'll stick to IE7 for the time being, at least the holes let the memory leak out of the bottom so other progams can use it.  Shocked
Midnight_Caller
Firefox crashed my computer, it is not geting back on.
I stil use Netscape Composer v4.7 week in week out for Web Authoring.    Cool  Cheesy
I stil use ClarisWorks as well it is the best.   Cool  Cool
VileReynard
Fixes: 20
FireFox has never caused me any memory problems in
Windows 98
Windows XP
Ubuntu (32 bit and 64 bit) - 3 machines.
7up
Fixes: 17
@Axis you are probably lucky. I was using v1 when it used to eat my ram up. I've not tried the latest versions as I simply don't trust it.
If they didn't fix the bug back then then I have doubts about them fixing it now. It was/is a random bug though which seemed to rear its ugly head if firefox had been running for several hours. IF your one of those users who uses a window, closes it and opens a new one regularly you probably won't be affected.
@Midnight Caller: Where can I get Netscape 4.7 from now? - That was the one I used many years ago and it was marvellous.
orbrey
I've had at least 4 tabs open for a week or so and FF is still using less than 100Mb, that's on XP SP2. Seems like the bug was fixed to me. Though the one on my work laptop does tend to crash daily (having said that it's merely an inconvenience due to being able to resume a session, and by resume, if I had a text box half full it will put the same text back in the box and let me pick up where I left off). Never have that problem at home though.
Midnight_Caller
Quote from: okrzynska
I can send you a copy if you PM me with your eMail Address.  Wink
7up
Fixes: 17
Quote from: PJ
e-mail isn't really suitable for sending files.
Thats true, but Yahoo don't have a inbox limit anymore so it won't matter at my end Wink
@Midnight - sending you a PM in a mo...
