Netgear N300 wifi extender
BKB
Can my Netgear extender be used on my Plusnet router? I've been into my modems setting but can't find anyway of adding it to the router access. Reference Netgear model: EX2700.
3 REPLIES 3
Fixes: 418
Re: Netgear N300 wifi extender
@BKB
Yes, they will work. This is set in the extender, not the modem. The easiest way to connect these devices is simply to use the WPS buttons on the hub and extender see https://kb.netgear.com/25533/How-to-install-the-EX2700-via-WPS
BKB
Thanks. What confused me was it said no internet but it was still able to connect to the Netgear setup.
Bogbody
Fixes: 4
I have one. Works fine.
Connect it using the WPS button.
