Netgear DG834 and daylight savings
Fixes: 8
Anyone else found that their Netgear router thinks daylight saving time has started?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
thejudge
Re: Netgear DG834 and daylight savings
Ooh yes, so it does! Have to see if there's a fix for that.
Fixes: 57
Mine doesn't DG834G v4
thejudge
A quick check suggests that the only way around this is to uncheck 'Adjust For Daylight Savings Time' (in'"Content Filtering' > 'Schedule') and putting the IP address of an NTP server in the boxes below that > 'Apply'.
It changed the time straight away, but now we'll have to wait until a fortnight on Sunday to see if it works for that as well.
Fixes: 57
Steve
Seasoned Pro
Thats the same as mine oldjim and mines is fine,but im using a Netgear DGN1000 Smiley
If life gives you lemons, make lemonade.
