Netgear DG834 and daylight savings
- Re: Netgear DG834 and daylight savings
10-03-2010 8:39 AM
Anyone else found that their Netgear router thinks daylight saving time has started?
5 REPLIES 5
10-03-2010 8:00 PM
Ooh yes, so it does! Have to see if there's a fix for that.
10-03-2010 8:15 PM
Mine doesn't DG834G v4
10-03-2010 8:16 PM
A quick check suggests that the only way around this is to uncheck 'Adjust For Daylight Savings Time' (in'"Content Filtering' > 'Schedule') and putting the IP address of an NTP server in the boxes below that > 'Apply'.
It changed the time straight away, but now we'll have to wait until a fortnight on Sunday to see if it works for that as well.
10-03-2010 8:19 PM
This is mine
11-03-2010 3:43 PM
Thats the same as mine oldjim and mines is fine,but im using a Netgear DGN1000
If life gives you lemons, make lemonade.
