Netgear DG834 V5
edgeways
Netgear DG834 V5
Does anybody know if the DGTeam software works on the latest netgear Dg834 router (DG54 Version 5 )
My existing Dg834 is gettig a bit flakey but I use the excellent DGTeam firmware to tweak and would not want to lose that option on the replacement router.
Thanks.
Mike.
Fixes: 62
Re: Netgear DG834 V5
As far as I know the v5 doesn't use a broadcom chip so the answer is that it won't
The chipset is apparently a Conexant CX94610
edgeways
Thanks for the info Old Jim. Do you know if any of the new routers support the option to tweak snr other than telnet? (The problem with telnet being that you have to retweak each time the router reboots).
Thanks and best regards ,
Mike (edgeways)
dusty_bin
I think pretty much anything, except the 834G.  I bought an 834 which was still at v4 - I queried and I don't think there were any plans to sell this one at v5 (but worth checking again).
Otherwise there is the DGN2000.
