Netgear D7000
Sheepdog10
Netgear D7000
Just moved to full fibre and want to use my older D7000, for a few reasons over the Hub2.
I connect it all and it then asks me for User name and password and if I want Plusnet TV active.
I assume from what I get it is connecting, Just will not let me login says user or password incorect with a little tick next to user name so I assume password is wrong or some other setting.
Can anyone help?
3 REPLIES 3
mystreet1
Seasoned Pro
Fixes: 7
Re: Netgear D7000
@Sheepdog10
Have a look at this page
https://www.plus.net/help/broadband/broadband-connection-settings/
Gives you what you enter where.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 480
Re: Netgear D7000
@Sheepdog10
If following the link from @mystreet1 you must use the third option: 'What settings should I use for a fibre router connected to an Openreach modem', that is, VLAN must be off. This function is handled by the full fibre ONT
Sheepdog10
Re: Netgear D7000
Thanks  @mystreet1.
Thought I had tried every combination, cannot have.
Connected straight away.
