Need to run a simple http/ftp server
- Re: Need to run a simple http/ftp server
10-08-2014 4:46 PM
Need to wget some stuff from inside my network, any ideas what is easy to use. Using mint at the moment.
3 REPLIES 3
10-08-2014 7:53 PM
How about Python?
waldo@jarlsberg:~$ python -m SimpleHTTPServer
Serving HTTP on 0.0.0.0 port 8000 ...
10-08-2014 10:44 PM
10-08-2014 11:08 PM
Thanks Waldo, that worked a treat.
@avatastic I had to upload a .img file to a router but it needed to be from a http://server so it turned out. I might check out rsync now you have mentioned it though. scp is my normal route for small file transfer.
