Need advice on creating home network
- Need advice on creating home network
14-12-2013 10:01 PM
Re: Need advice on creating home network
14-12-2013 10:32 PM
14-12-2013 10:54 PM
14-12-2013 11:27 PM
14-12-2013 11:29 PM
14-12-2013 11:37 PM
14-12-2013 11:50 PM
Port 1 - Router
Port 2 - Desktop PC
Port 3 - HTPC
Port 4 - NAS
15-12-2013 12:18 AM
if you have too many gadgets in one room.
You can connect a 100Mbps switch into a 1Gbps switch for cheapness.
15-12-2013 10:33 AM
If the 8 port is only a few quid dearer than the 5 get it, you will thank yourself down the line (if it is a lot more expensive then don't)
15-12-2013 11:12 AM
15-12-2013 12:18 PM
and that seems to do the job perfectly well at a very low cost compared to my preferred Amazon : Netgear GS608.
17-01-2014 4:07 PM
17-01-2014 4:42 PM
Then install a great many power points.
19-01-2014 8:55 PM
