NTE5C?
Manny7860
NTE5C?
13 REPLIES 13
rongtw
Fixes: 12
Re: NTE5C?
Had one fitted several months ago , fixed my intermittent problem Thumbs_Up
Manny7860
Re: NTE5C?
That's good to hear. Thanks for feedback. They look simple to install. Push down clip.
Excellent!
VileReynard
Fixes: 20
Re: NTE5C?
Had a similar one fitted recently; the plastic bag says it is a
NTE5c MK2/VDSL Frontplate MK4 combined unit.
It gives a much improved download speed.
Manny7860
Re: NTE5C?
That's good.
Sounds like the same one. Any picture.
Excellent!
VileReynard
Fixes: 20
Re: NTE5C?
Sorry, no picture but it looks like it is one of these:-
https://www.run-it-direct.co.uk/adsl-vdsl-faceplates/mk4btopenreachvdslsocket/
including the instructions?
https://www.run-it-direct.co.uk/MK4VDSLNTE5Cinstructions.pdf
Manny7860
Re: NTE5C?
Yeah looks like the same one pal. They call it mark 4 fourth version I believe
Excellent!
DaveyH
Champion
Fixes: 12
Re: NTE5C?
Have a read of this thread
http://forums.thinkbroadband.com/fibre/4532655-new-mk4-faceplate.html?fpart=all
The general consensus is they're cheap tat and not worth 'upgrading' from older NTE5s
Manny7860
Re: NTE5C?
It's just the outer case is a bit flimsy due to it being a push on/ off fit.
Them guys in the forum had a problem with line so its not a quick fix its not going to increase speed or a previous fault. Just there for stability it has a updated Rein filter and RF filter.
Excellent!
Manny7860
Re: NTE5C?
Some info here on what's on the insides
https://youtu.be/jD67a-ZC7VY
Excellent!
Manny7860
Re: NTE5C?
So the NTE5C socket and Mk4 front pre filtered faceplate is a good combination to use.
Excellent!
Manny7860
Re: NTE5C?
@rongtw what faceplate you got on your nte5c socket?
Excellent!
Browni
Aspiring Hero
Fixes: 60
Re: NTE5C?
The "telephone engineer" in the link from the 1st post seems rather clueless!
This is fibre to the cabinet (FTTC) VDSL. I have seen this perform at almost 60Mb download. Astonishing!
Funny
It seems like Openreach want to get users to install the BT Openreach New NTE5C Master Socket themselves!
The master socket is Openreach's demarcation point and not to be touched by us mere mortals.
VileReynard
Fixes: 20
Re: NTE5C?
I think BT want people to do their own wiring for extension sockets.
Except that almost everyone wouldn't wire into the socket (assuming they didn't use DECT). Cheesy
