NTE Power Status
dws1900
NTE Power Status
Hi
Can someone explain this parameter?
I have googled, but get a load of GEA reports (including ones on this board)
7 REPLIES 7
Fixes: 1,495
Re: NTE Power Status
Moderators Note
This topic has been moved from Fibre to Tech Help
VileReynard
Fixes: 20
NTE = Network Terminating Equipment, basically the BT socket which is the point which divides BT faults from user faults.
Compare with NTE5A socket etc
dws1900
Hi
Thanks for the reply, but what does the Power ON (and presumably Power OFF?) mean?
VileReynard
Fixes: 20
I'm guessing its only relevant to a large business installation, where the NTE is a piece of electronic equipment - not just a BT socket!
dws1900
Hi
On my GEA's, it shows POWER ON, but its just a standard NTE faceplate with phone & broadband sockets,
no other power source.
Also on the BT AdslChecker it shows the NTEFaceplate as N.
ejs
Aspiring Hero
Fixes: 25
The NTE for FTTC used to be the Openreach Huawei HG612 or ECI modem.
Maybe it just indicates if your modem is on or off.
dws1900
Hi
All GEA's have the same status as does the BT checker.The only modems used are the PN Hub (white one) and a Vigor.
One of lifes's mysteries
