.NET framework
.NET framework
While installing some (blood pressure monitoring) software. I was offered the option of installing MS .NET framework (1.1 I think) that the software quote uses occasionally. I accepted the option. I was amazed just how long this took to install. At the configuration stage the progress bar (I lost count) must have been refreshed at least 10 times and might have been more. Again I wasn't watching a clock (not expecting this) but it must have taken 10 to 15 minutes to install the .NET framework before getting round to installing the BP software.
Without getting into the ethics of my installing things when I don't know what they're for; what exactly is .NET framework? What's it used "occasionally" for? and what would have been the effect of taking the "No" option?
I was also surprised that after all this seemingly complex install, I would need a mandatory restart, but it didn't. Other than this, it all "seems" to be working Ok.
Re: .NET framework
Basically it is a set of pre-built functions for various things like screen layout, field input etc that you can used to create  applications. It allows you to create small applications (thus quicker/easier to download) which then use the .NET libraries already installed on a PC.
It was MS's attempt at a IDE / RDE (Integrated Development Environment / Rapid Development Environment) as the hope was the .NET framework libraries would be developed for other OS's (e.g. Linux, Max OS) so making your applications portable. It never took off!!!
There are currently 3 versions .NET 1.X, .NET 2.X and .NET 3.X and all range from 40 to 120MBs in size, hence why it took so long to install!
http://andymcm.com/dotnetfaq.htm
Re: .NET framework
Thank you Peter.
br1anstorm
Re: .NET framework
Just happened to see this subject when browsing the forum... and it reminded me that when I was looking for a (free) CD-burning app, one that I looked at was CDBurnerXP.  But their site said - rather defensively - that it also required installation of the .NET framework ... "which many people don't like".
I didn't know what the .NET framework was, but that reference was enough to put me off!
BTW I'm still looking for decent free CD-burning software...
br1anstorm
Re: .NET framework
It's possible you may find free burning software, and decent burning software, but you may not find them both in the same place.
I fundamentally understood Peter's definition of .NET framework, but not what difference it would have made if I had taken the available option not to install it...if you see what I mean. The software in question is there to produce daily/weekly/monthly graphs of blood pressure readings, pulse rates etc. and track trends etc. in a format that will be understood by the medical profession. Does this mean if I hadn't installed .Net framework, it wouldn't do this, if so why have it as an option? if you see what I mean... As it stands, with the .Net it works just fine, but would it have done so without it?
Re: .NET framework
Some functions of the software may not have worked and thus may have been greyed out on menus if .NET did not exist. Whether the actual recording would work I don't know but given the fact it was optional probably means it would function as described but with less functionality like graphs etc.
There are very few programs that rely on .NET anyway as it never really took off.
Fixes: 10
Re: .NET framework
Do you remember when certain programs written in Visual Basic required you to get hold of the appropriate VB run-time dll (MSVBVM60.DLL etc.)? Well .NET is the infinitely bloated successor to that.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: .NET framework
Thanks again Peter.
And yes jelv, I do remember that now you reminded me, thanks.
