NAS Storage
Champnet
Fixes: 21
Re: NAS Storage
@Mav  Fraid not, we're talking memory for the NAS. Synology's own memory costs a lot, but most use compatible ones........
If it comes with 4GB you could add 4 =8GB, or add 8 =12GB, or replace the 4 with 2x8 =16GB
Mine came from Crucial 4 years ago so specs and prices may have changed.
CT2C8G3S186DM.M16FN 2-8GB DDR3L-1866 SODIMM 1.35V CL13
£120.99
1
£120.99
RobPN
Fixes: 15
Re: NAS Storage
@Mav wrote:
@RobPN
The budget of £500 is for the NAS unit ex HDDs
Fair enough @Mav , I was going by this;
@Mav wrote:
... I could possibly get 4 x 6TB drives for less than £500. ...
Mav
Fixes: 518
Re: NAS Storage
Thanks for all the advice guys.
I'm holding back on the NAS for a while as I have just spent a small fortune on a Ryzen 9 5950X self-build PC for photo and video editing and two new 32" monitors😎
Shhhhh Don't tell SWMBO🤐
Forum Moderator and Customer
Champnet
Fixes: 21
Re: NAS Storage
Sold the car to your Daughter ?
Mav
Fixes: 518
Re: NAS Storage
Already bought her a 2008 Land Rover SportCrazy
It's been more trouble than it's worth and is, yet again, in the garage for repairs all under warranty, thankfully.
Mook
Seasoned Champion
Fixes: 9
Re: NAS Storage
@Mav Two 32" Monitors, you could end up looking like Sid from Ice Age with that amount of estate in front of you. I can't fully see my 27" Apple and 27" LG. Thumbs_Up
Mav
Fixes: 518
Re: NAS Storage
I'm a bit worried they might be over-kill but they've received excellent reviews.
madswitcher
Re: NAS Storage
Have you thought of a DIY solution?
There are some excellent free NAS software suites available where you can take an old PC tower, populate it with some discs and build your own NAS.  I have used a HP Microserver that has 4/5 disc bays and put OpenMediaVault on it.  It works very well and goes very very fast.  You can also learn a new skill in building it.  The documentation is also very good.
For the Client side of this I use Filezilla which is also free of charge.
I forgot to add that you get a HP Microserver off Flebay for a loss less than £100 and can make the whole thing boot from a USB stick and so don't lose a disc for a system disc
Champnet
Fixes: 21
Re: NAS Storage
I had an HP microserver gen 4 running netware 4, highly recommend, ridiculous pricing on EBay....
VileReynard
Fixes: 20
Re: NAS Storage
Is netware still a thing?
I once tangled with Netware 3.x and it was horrible.
Champnet
Fixes: 21
Re: NAS Storage
Strange, I worked with versions 2,3 & 4 and found 3 was the easiest. I did eventually get to grips with NDS in 4...........
