N95 Plustalk settings
- N95 Plustalk settings
- « Previous
- 1
- 2
- Next »
Re: N95 Plustalk settings
22-11-2007 8:56 AM
i just get registration failed.
its also added a profile in internet telephone bit where it tries to connect with 3G but just hangs
i use fring on my n95 alot to make calls to people over the 3G it's very good.
shame this SIP direct from the handset doesn't work for me it would be great
27-11-2007 8:04 PM
Hurrah just got my E65 working on the plustalk voip trial at last
now i can use those free minutes
29-11-2007 9:24 AM
PJ,
Just looking here
It looks like the port for the Registrar Server should be 5060 and not 5082.
Hope that helps
Edited to hyperlink URL that was stretching forum layout.
Just looking here
Hope that helps
30-11-2007 12:04 PM
Here are my settings for the N95 and the VoIP BETA. I'll add them to the sticky in this forum too.
Select Menu > Tools > Settings > Connection > SIP Settings
Select Options > New SIP profile > Use Default Profile
Enter the following settings (where 1234567 is your SIP ID)...
Profile name: Gradwell
Service profile: IETF
Default access point: Your WLAN/GPRS/UMS connection
Public user name: sip:1234567@sip2.plus.net
Use compression: No
Registration: Always on
Use security No
Next, select 'Proxy Server' and enter the following settings...
Proxy server address: sip:sip2.plus.net
Realm: sip2.plus.net
User name: 1234567
Password: Your BETA trial password
Allow loose routing: Yes
Transport type: UDP
Port: 5060
Now press 'Back', select 'Registrar server' and enter the following settings...
Registrar server address: sip:sip2.plus.net
User name: 1234567
Transport type: UDP
Port: 5060
Click 'Back' and after a few seconds (assuming you have WLAN connectivity) the account should show as registered. If you get a warning about WLAN availability then just accept it.
Click 'Back' and go to 'Internet tel.'
Click Options > New profile
Select the sip2.plus.net SIP address
Call the profile something relevant (Like 'Gradwell') and click 'Back' to save the settings.
Dial a number, click 'Options' and select 'Internet Call'
Please note that the 'Internet Call' option may not be present. If it isn't then there's a possibility that your provider has removed the VoIP functionality of your handset. If you are using GPRS/UMS then there amy also be restrictions at that layer that are preventing you from making calls or registering with the service.
Use compression: No
Use security No
User name: 1234567
Transport type: UDP
Port: 5060
User name: 1234567
Transport type: UDP
Port: 5060
30-11-2007 3:36 PM
I have an E65 on orange and it works just fine with the new plustalk beta trial so maybe they only remove voip functionality from certain models of handset .
- « Previous
- 1
- 2
- Next »
