MySQL connection via PC app
- MySQL connection via PC app
19-08-2007 10:49 PM
I have added the settings, host = rumpus or humbug.plus.net username=*** password =*** etc and tried connecting on the default port 3306. But i get an error, cannot connect.
Can you confirm the port setting?
I cannot add the database name to the connection settings of this app until i have connected to the server.. is that the problem?
Re: MySQL connection via PC app
21-08-2007 4:43 PM
This certainly used to be possible (and I'm not personally aware of any changes we've made recently to lock down access). What application are you trying to configure?
Quote I have added the settings, host = rumpus or humbug.plus.net username=*** password =*** etc and tried connecting on the default port 3306.
Which server should you be using? You mention both rumpus and humbug in your post? You will need the full server name which will be /either/ rumpus.plus.net /or/ humbug.plus.net.
22-08-2007 11:18 AM
The Program is Auto Backup for MySQL pro edition 2.1 by swordsky. I have successfuly setup up for another host so it cannot be a firewall issue.
I think its because i cannot add the database name in the settings.
Error is
22-08-2007 11:53 AM
22-08-2007 11:58 AM
22-08-2007 12:34 PM
Your password needs to be the long string that you will have been emailed when you first set up MySQL access with us (note that it can't be changed to something nicer).
22-08-2007 12:43 PM
Quote from: pberry Your username should be your standard account username.
I can access the database using the the Username and password that was emailed, using myPHPadmin. The Username and password that was emailed is applied to the above settings.
The Test connection then tries to connect, giving error and i suspect its not allowing me to view all the databases on rumpus.
22-08-2007 12:51 PM
22-08-2007 12:52 PM
Quote from: Chapster
I've downloaded the trial version of what your using from their site and get a successful test connection and when proceeding to the next step it shows me all the tables under username_visp (which in my case is pberry_pn). You won't get all the databases under rumpus or humbug, as each customer only has one and can only see and use that one.
22-08-2007 12:57 PM
22-08-2007 1:06 PM
I suppose the answer is double or even quadruple check you have added the correct username and passwords
07-11-2007 9:45 PM
Quote from: Chapster How come everytime i post on a forum i end up redfaced because its something silly (like a password). I rarely use forums this is about the fifth time i have ever started a topic in 8 years.
You'd be surprised how you can arrive at an answer simply by talking about it (externalising your thoughts). Happens to me all the time.
