My first post! And a problem already! Doh!
- Re: My first post! And a problem already! Doh!
22-03-2009 4:31 PM
My Plusnet connection just went live yesterday. My router is connected to my desktop PC via Ethernet, and all is well there, and our laptop seems to connect wirelessly OK too. However, I also bought a wireless adaptor for the PC, and the thing refuses to connect, (XP telling me "there is no or limited connectivity" , even though Plusnet link quality and signal strength are recorded by the wireless adaptors configuration tool as being at least 92%, and the router is about three feet away from the PC! The PC just wont connect to any websites at all. Now you might ask, why dont you just use the Ethernet connection then? And you would be right, but I just want to understand why the silly wireless gadget wont work. Tried installing its drivers twice, with identical results. Does it matter if an Ethernet cable is still connected when you try wireless? I tried plugged in and unplugged, with same result.
22-03-2009 5:02 PM
Are you absoluately sure the wireless code is typed in correctly?
22-03-2009 5:05 PM
22-03-2009 5:41 PM
Do you have an ip from the wireless adapter? You say it is seeing the router, fine, but is it connected?
If you could open a command prompt and type "ipconfig" into the window and copy the results here we maybe able to help more.
Also with ONLY one connection live if you type "ping bbc.co.uk" into the window what results are shown?
NB the above commands should be entered WITHOUT the "''s
22-03-2009 6:59 PM
22-03-2009 8:06 PM
To answer as many replies as possible,
Old jim, yes there is and yes I have, thats how I know that it sees the router and connects to it, and also the plusnet signal strength.
Emma, forgive me, newbie to broadband here, can you explain what this means, and how I check it?
Also biker955, (got a Tumpet by any chance, same here?!) I tried ipconfig, got a box that disappeared in a flash, before I could read anything in it! as above, can you explain exactly what you mean by an ip, and how do I check it?
Once again, thanks everybody.
22-03-2009 8:30 PM
AN IP address is a unique code that identifies your computer on a network. You will have a web IP address, which is assigned by Plusnet, but you will also have a local IP address for each PC on your network. The ipconfig command will tell what the number is, and might show what the problem is.
Click <a href="http://www.ncsu.edu/resnet/windows/ipconfig/">here</a> for some illustrated instructions.
Edit: oops, fixed link
23-03-2009 5:20 PM
Thanks for that.
The info produced by iconfig was as follows:
DNS suffix....lan
IP Address....192.168.1.64
Subnet Mask....255.255.255.0
Default Gateway...192.168.1.254
I should point out that this was carried out without the adaptor in place, ie connected via cable.
regards
23-03-2009 5:30 PM
Quote from: ImpretSir Also biker955, (got a Tumpet by any chance, same here?!)
Yep got an ST 955 like the pic, currently on an SORN As I cant afford the insurance/tax/petrol/etc
24-03-2009 9:19 AM
adie:quote
24-03-2009 9:25 AM
I just did the ipconfig test with the wireless adaptor in place, and got these results.
DNS ...Media disconnected
Ethernet adaptor wireless network connection:2
DNS suffix: (blank)
Autoconfig IP address: 169.254.107.57
Subnet Mask: 255.255.255.0
Gateway: (blank)
Any ideas? I am still getting the "you have little or no connectivity..." message from windows.
regards
24-03-2009 9:32 AM
I would check as Emma suggested that you have typed in the password correctly, it is case sensitive and 0 and O's are correct.
24-03-2009 9:45 AM
Quote from: ImpretSir Autoconfig IP address: 169.254.107.57
That ip shows that IT doesn't have an ip address *Silly eh* XP will put in an 16.254.x.x address if it cant get an ip from a dhcp server (i.e. your router)
As suggested check that you have the correct password/protocol set (WPA/WEP/WPA 2 etc) in the wireless setup, I would open the wireless control panel and re-enter all the details for your router.
24-03-2009 11:05 AM
24-03-2009 11:14 AM
When you connected to the wireless network is should have asked you for a password.
On the underneath of your Plusnet supplier router is the password you should have used.
To re-enter this right click your wireless connection icon and select view wireless networks you should then see the plusnet connection, click connect and enter the password as shown on the router.
