My firestick won’t connect
- My firestick won’t connect
24-08-2019 11:49 AM
My firestick is the only device that won’t connect to my WiFi, I tried everything from moving the stick directly next to the router, to buying a wifi booster. But nothing is helping. Sometimes it will go to a pop up of plusnet, but then go straight to the amazon.com homepage, then when I click out of it, it says the WiFi isn’t connected.
1 REPLY 1
Re: My firestick won’t connect
25-08-2019 1:39 PM
What band you using?
Ever helpful.
Sure, I’d love to help you out. Now which way did you come in?
