My eyes are dim:I cannot see. Monitor why are you cruel to me?
Luzern
Seasoned Champion
Fixes: 5
Well perhaps that title is humour, where I feel lacking in it.
I have a 22" w/s 1920*1080 monitor. The print I see when visiting sites is minuscule, less than 8pt. I have tried several ways to set it permanently to a larger size without success.
All advice welcomed!
23 REPLIES 23
Re: My eyes are dim:I cannot see. Monitor why are you cruel to me?
Would you like instructions for every web browser that is available?
(or you could tell us which one you prefer to use)  Wink
Fixes: 25
My advice would be to think more carefully next time you buy a monitor.  1920 x 1080 is a lot of pixels.  22" isn't that big, so you have a lot of pixels in a small space.  I'm using a 19" monitor at its recommended resolution of 1440 x 900 pixels so everything else being equal I see things about 15%  bigger than you do.  You would need a 25" monitor (at 1920 x 1080 resolution)  to see things the same size.
Fixes: 21
Try holding down control and pressing the + on the numeric keyboard.
In FF goto edit/preferences/content tab and change the Default font size there. If you aren't using FF why not? (FF=FireFox)
Or Ctrl+Mouse wheel zooms in and out for a lot of apps (definitely FF and Word).
VileReynard
Champion
Fixes: 16
Quote from: lucerne
On my 22" 1680x1050 pixels screen,
that sentence (183 characters) requires almost the full screen width using a monospace (11 point) font - but only requires 11" (proportional font) as shown in the forum (full screen) - equivalent to just 4.3 points!!
Luzern
Seasoned Champion
Fixes: 5
Quote from: HPsauce
Firefox.
Luzern
Seasoned Champion
Fixes: 5
Quote from: ReedRichards
I wish I'd known, but "stable door and all that". It was the one on free upgrade offer. I wonder how many others have been less than Dellighted. Undecided
Fixes: 10
Try going to the display properties and on the appearance tab select larger font size.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
VileReynard
Champion
Fixes: 16
Quote from: lucerne
But you wouldn't see more with a bigger monitor - and LCD screens don't tend to run nicely at other than their native resolution.
Get a CRT if you want to mess with dpi.
Fixes: 10
If you really need to see a lot more on your desktop there's only one way to do if - but you need the space and money.
Here's a screen shot of my desktop.
Quote from: lucerne
Firefox.
Sadly I'm an IE8 user (and some other browsers but not FF) so can't give specifics on FF, hopefully someone will do so soon.
(For the record IE8 has options on the View menu to adjust text size and overall "zoom", both of which "stick" so I guess FF would be similar.)
There are also many options in Windows to adjust text sizes etc. for those with visual limitations, operating across all applications not just the web browsing you asked about. It's nearly always best to run the display itself at "native" resolution and adjust with other settings.
The settings are better organised and more logically accessible in Vista/W7 compared to XP, you don't say which you're using?
James
He could make it large or make it bright.
Hit control and plus for quite a sight!
It might be big and a little blurry,
But he'll be able to see, so not to worry!
Fixes: 21
Quote from: Hairy
From the 1st answer
VileReynard
Champion
Fixes: 16
Don't forget to use the advanced options so that you can set a minimum font size. Cheesy Cheesy Cheesy Cheesy
