My Server Spec
- My Server Spec
My Server Spec
17-02-2014 9:18 AM
Hello guys! I finally got my Sever sorted out!
Anyways I'll put up the specs for you now.
8 REPLIES 8
Re: My Server Spec
17-02-2014 9:37 AM
Windows? on a server? hehe - depends if you need all the features of outlook etc I s'pose...
What you using it for, or planning to use it for?
All of my bases are belonging to linux
Re: My Server Spec
17-02-2014 9:44 AM
.. and then I spot your tiny bit older thread. Pleased you got it all sorted dude
Re: My Server Spec
17-02-2014 10:17 AM
I'm using it as Domain Controller for whole house. I've got more servers. Proper power hungry ones!
I'll post some images as well, The servers which I have are, Dell PowerEdge R200 and a Dell PowerEdge 2950
Specs for the R200 - 1x Dual core Xeon with 4GB of ram 250GB OS drive and a 500GB Backup Drive (running Windows 2008 R2 Enterprise)
Specs for the 2950 2x Quad core Xeons with 32GB of ram, 5x 150GB SAS Drives. (running exi5.5)
In the gray box. I've got some Cisco Networking Equipment. 2 Switches and 2 Routers.
Re: My Server Spec
17-02-2014 10:55 AM
Is the Belkin held on by bluetack
Re: My Server Spec
17-02-2014 11:30 AM
Nope. Its the Cisco 2950
I don't have any rack ears for it.
Re: My Server Spec
17-02-2014 11:56 AM
So it's a Cisco flavored Belkin wrap
Subway will be jealous you know
Re: My Server Spec
17-02-2014 12:05 PM
OMG. I didn't notice the Wireless Adpater. ._. I thought you talking about something else. My bad.
Re: My Server Spec
17-02-2014 12:08 PM
OOps my bad for the confusion
